SailNet Community - View Single Post - Tips and tricks for getting rid of crab/lobster floats
post #18 of Old 06-22-2012
klem
Re: Tips and tricks for getting rid of crab/lobster floats
Originally Posted by dmcMaine View Post
I've seen a few boat while shopping that have installed cages around prop/shaft. Not sure how well they work to avoid lines.
I've run over a few lobster floats so far, but haven't become fouled on one yet. Then again, I haven't sailed anything with an inboard yet either....
As DivingOtter said, cages can be a nightmare. Very few are closed on the aft end so they are still susceptible in reverse. I have seen the whole works bent up more than once with the actual buoy inside the cage.
In Maine, I think that a lot of buoys could be saved if they put their toggles much closer to the pickup buoy, like 4' not 30'. They would be slightly harder to pick up but you wouldn't be forced to run between the buoys and toggles. A timed release of the buoy could be cool. The low tech way of doing this is bags of salt but that would be a whole lot of salt.
klem is offline
