SailNet Community - View Single Post - Catalina 38 pros and cons
post #67 of Old 06-22-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Catalina 38 pros and cons
Just found this old thread and I have a question for JeffH.
I've noticed in your criticisms of IOR boats that you make no distinction between the first generation IOR I boats, like the Yankee/Cat 38 and the later boats from IOR 111 and 111A. They both have the big foretriangle and small stern but the later boats (post Ganbare) have quite different hull shapes - flat bottoms, no or little rocker, no or little deadrise, low initial stability, high CG etc.
These later boats were the ones that suffered all the maladies you complain of re: handling and seaworthiness while the earlier ones like the Cat 38, Swan 38, Hughes 38 etc. seem to do much better in that regard, albeit a little more slowly.
Do you in fact see the two generations of IOR design differently or do you see them all with the same jaundiced eye?
SloopJonB is offline
