SailNet Community - View Single Post - Bedding Deck Hardware With Butyl Tape
post #189 of Old 06-23-2012 Thread Starter
Maine Sail
Maine Sail's Avatar
Re: Bedding Deck Hardware With Butyl Tape
Originally Posted by DryRed View Post
I have one question, I'm esealing around my chain plates. I want to pour thinkened epoxy around the chain plate to seal the balsa and ensure no water get in. I also want to leave a uniform gap between the hardened epoxy and the chain plate so that I can seal it. Could I install the chain plate wrap the chain plate with butyl tape then pour the thickened epoxy around the butyl tape so that once it hardens the butyl tape will be sealed against the chainplate?
I generally prefer to wrap with packaging tape or electrical tape. The heat of the epoxy cure may soften the butyl. Electrical tale works well.... Butyl works in compression so even after the pour you'd need to re-bed. If potting the core put a slight chamfer in the deck hole around the chain plate.
______
-Maine Sail / CS-36T
Maine Sail is offline
