Also, you should be aware that some of the hard-coat bottom
paints require the boat to be splashed in a certain amount of time after applying the
paint. If you do not splash the boat in the required time frame the
paint effectively becomes inactivated, and may need to be removed and repainted.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
