SailNet Community - View Single Post - AC logic please for bypass of inverter
post #2 of Old 06-25-2012
mitiempo
mitiempo's Avatar
Re: AC logic please for bypass of inverter
Chip
Probably the best way to wire an inverter is for its output to go to a separate panel that only has the breakers on it for those items that you want the inverter to run.
Where are your circuit breakers for the AC circuits - I only see the 30 amp main which will not protect outlets downstream?
Brian
mitiempo is offline
