SailNet Community - View Single Post - Life vests for the well-endowed
post #20 of Old 06-27-2012
Geoff54
Geoff54's Avatar
Re: Life vests for the well-endowed
Originally Posted by Brigala View Post
What is the difference between those ones and these ones:
MD2087 M.I.T. Membrane Inflatable Technology™
I can't figure out any significant difference between the Deluxe one you linked and this one (other than the available colors - and I just want something bright and visible). But this one is about $60 less.
At a quick glance, the major difference is that the more expensive one has a hydrostatic trigger, which uses water pressure rather than inflating when it gets wet, which reduces the chance of it inflating accidentally. I didn’t look very closely but the more expensive ones tend to have extras like soft collars and inspection windows to check on the firing mechanism.
Don’t worry about the color (from a visibility point of view), they open up when inflated and are then all brightly colored, usually yellow.
Shop around for the best deal you can get. Depending on your level safety consciousness and where you use it, a crotch strap and a spray hood are nice features to have (they all come with a light and whistle, right?). Also I found some more comfortable than others, although I am a slightly different shape.
BTW, I got mine in Europe because, for some reason, inflatable lifejackets are (or at least were) less expensive there. Don’t know why.
Geoff54 is offline
