SailNet Community - View Single Post - Beneteau 36CC does not reach hull speed
post #7 of Old 06-28-2012
Dog Ship
Dog Ship's Avatar
Re: Beneteau 36CC does not reach hull speed
I have the same engine and a 2.21:1 ratio gearbox in a C&C 32. I believe my hull speed is around 6.5 knots.
At about 12,000 lbs. fully loaded and with a 16"x14" fixed 3 blade prop at 2800 rpm my boat will cruise at 7 gps knots in any reasonable conditions.
It sounds like your boat may be under propped or under geared. My boat is a bit over propped but it seems to do ok.
There are two gearboxes for this engine. One is 2.21:1 and the other is around 2.8:1 if I remember right. Find out which one you have before you make a prop decision.
If you have a feathering prop you can have them repitched for a better bite. If it is a folder then maybe it is a bit small for your application.
I never run my 3gm30f over 3 grand. I don't think I have ever had it at wide open throttle, ever.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
