SailNet Community - View Single Post - changing tire on trailer with boat on trailer
post #1 of Old 06-28-2012 Thread Starter
johnnyandjebus
johnnyandjebus's Avatar
Hello all
The tires on my trailer are old and need to be replaced. One in particular is really bad, a bulge on the inside side wall. I have the new tires but am concerned about swapping them. Reason being the boat is on the trailer. A Contessa 26, 5400 lb's. The trailer is a dual axle.
Two concerns;
1) Will the boat shift if I lift the trailer?
2) Where to I put the jack to lift the trailer? I don't want to load up the trailer in a weak spot.
Any thoughts?
Am I over thinking this?
Ideally I would like to replace both rear tires and leave the front two until the boat is off the trailer(next spring) the rear two are in worse shape than the front two.
Thanks,
John
"The more I know about people, the better I like my dog."
-- Mark Twain
"If you canít explain it to a six year old, you donít understand it yourself.Ē
--Albert Einstein
johnnyandjebus is offline
