SailNet Community - View Single Post - Fuse board
Thread: Fuse board
post #2 of Old 06-28-2012
Wayne25
Wayne25's Avatar
Re: Fuse board
My master pull out switch is 2 position. Sounds like someone changed it out with something different. I had to replace some of mine also. Just make sure you get the correct ampere switch. Mine also had an additional switch board installed next to the original for more gear to be installed.
You may also want to look into a more modern battery 1, 2 or both switch. This would allow you to add another battery for more capacity. You could turn your existing power switch into use for something else.
Wayne
Rehoboth Bay/Indian River, DE
S/Y KJ, Helms 25
1976 #552
Wayne25 is offline
