SailNet Community - View Single Post - Motor mount replacement?
post #5 of Old 11-07-2006
sailingdog
I would also check the other motor mounts, and replace any that look a bit questionable. It is likely that the other ones may also be close to needing replacement, so you might as well do it while you're at it... and save yourself the trouble of re-aligning the motor several times later on.
sailingdog is offline
