SailNet Community - View Single Post - Spirit keel removal
post #2 of Old 07-04-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Spirit keel removal
Originally Posted by sailor2800 View Post
I'm restoring a 1978 Spirit 6.5 sailboat, I need to remove the keel for repair.
I appears that the keel nuts inside are covered and not accesable. Anyone know to get to the nuts.
Thanks
Sailor2800
They have probably been sealed in with globs of resin. If you can at least see the bumps where they are, get out the jackhammer!
Just kidding but you will need to get a sharp but unloved chisel and clean away the covering.
If you can't even deduce where they are from lumps in the correct area of your bilge, you'll need to get a pro or a surveyor to find them for you I guess.
SloopJonB is offline
