I crewed on a Cal 2-30 "RAMPAGE" out on the SF bay, doing the MORA series. Check out sailplan on BACON sails. its a 7/8 fractional rig. PHRF should be around 178-180 depending on pole length, max size headsail. etc... I believe that the Cal 2-30 might have the dreaded steel beam that may need replacing. Some owners have used a bore scope to check their beams. She is narrow for the weight and will do well to weather even in rough chop and heavy seas. She will scoot in a blow with a chute up. Had her up on a plane on some big rollers coming in from the light ship. Good access to the Atomic4, and some had monel water tanks. LOA = 30' 8"
LWL = 25' 0"
Beam = 9' 0"
Draft = 5' 0"
Displacement = 10,300 pounds
Ballast = 4,500 pounds
I = 37'
J = 12.33'
P = 35'
E = 13.5'
