SailNet Community - View Single Post - Throttle cable releasing back to idle
post #1 of Old 07-07-2012 Thread Starter
patrscoe
patrscoe's Avatar
Since we purchased our sailboat late last year, the throttle has no tension and springs back to idle if I let go from the handle. The Yanmar has an internal spring and The Edson model I have (throttle on the side and shifter in the front) does not have a tension screw. I read on previous posts that you can put a Morse cable brake part #44386 on the cable, using this as a tension seems like it would damage the cable over time.
Any thoughts on the proper fix?
Patrick
S2 11.0A 36'
Kinsale, Va
Tanzer 16'
Moseley, Va
patrscoe is offline
