SailNet Community - View Single Post - When is the best time to check oil?
post #13 of Old 07-08-2012
sawingknots
Re: When is the best time to check oil?
i agree that the oil should be checked before starting but be sure to wipe the stick and reinsert because oil will sometimes climb higher than the actual level,actually the best time to check is anytime you suspect it could be low,hot or cold,just allow a few minutes for most of the oil is draned back into the pan
sawingknots is offline
