SailNet Community - View Single Post - Pros and Cons of Loose Footed Sails
Old 11-08-2006
sailingdog sailingdog is offline
Another advantage of the loose-footed main, if you use sail ties, you can run them around just the sail at some points to help keep the sail bundled neatly. This is hard to do with a bolt-rope foot main. Same thing with the reefing points. This might actually save the sail if you try raising it and forget to undo the reef point ties, as the reef points are anchored to the boom but to the loose foot of the sail, which has far more give.
