SailNet Community - View Single Post - Premature impeller failure cause
post #9 of Old 07-09-2012
Cruisingdad
Best Looking MALE Mod
Cruisingdad's Avatar
Re: Premature impeller failure cause
Originally Posted by LinekinBayCD View Post
I checked the strainer and pulled the hose off the thru hull. Got a gusher when I opened the sea **** so I think the water flow is good but maybe it's not good enough. Kind of like sucking through a thin straw vs a wider one?
I am beginning to suspect a product failure if you have followed the installation steps I discussed. Replace the impeller with Westerbeke parts. All I use are Yanmar direct parts - no aftermarket. Replace every 12 mos or 100 hours.
Replace your impeller as I described. Give her a good run for some hours. Open is and take a look at the impeller. Also, at 55ish HP, you should put out about 5 gallons of water/minute from the exhaust. Stick a bucket under there and see what you get. THat is what the specs are for Yanmar anyways, IIRC. CHeck out the amount with Westerbeke.
Hope these suggestions help. ALso, make sure your hose is not collapsing under higher rpms (from Thull/strainer to block).
Brian
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
