Genny
The difference is size. Most properly made modern roller reefing genny's have foam in the luff of the sail so when you roll it in partway (reef) it will still have good sail shape. The trick to reefing it in is to make sure you have tension on the clew so it does not flop all over, or wrinkle up. Reef before you need to.
