Re: Need an engine part that apparently doesnt exist anymore
Denis030 has it right. You just need a nut of the right size that will stay in place. You also need to figure out whether it is imperial or metric so if you can bring the shaft with you when shopping that might be handy. Be sure to get it in stainless. You may have to drill a hole through a regular nut if the position of the cotter pin through the shaft is not compatible with what you can find.
