SailNet Community - View Single Post - I28 - Mosquito Protection for Main Hatch
post #1 of Old 07-16-2012 Thread Starter
Sundayflyer32
Just wanted to share that I built a nice mosquito protection hatch for my I-28. The companion way on my 28 has the main sliding hatch and inside below the runners for the hatch, are strips of teak that run along under the hatch. These are perfect for a hinged slide-in frame that you staple screening onto.
The gap between the main hatch and the teak rails under is about 1" so any framing material 3/4" thick by 1" to 1 1/2" inch wide is suitable. I couldn't find any suitable teak so used cheap finger joined pine. Measure carefully the width between the glass sides of the companion way at the forward and wash board ends (not the same width) as well as the length between the forward end and the companion way with the boards in place. I hinged mine so that you can leave the screen in place to allow for easier entrance.
Carefull measurement will allow the screen to remain in place and allow you to slide the main hatch overtop and allow the washboards to remain in place.
I can provide pictures if requested.
Sundayflyer32 is offline
