SailNet Community - View Single Post - Long time dreamer, recent sailer
post #22 of Old 07-17-2012
Re: Long time dreamer, recent sailer
that's great that you found another one. If you wouldn't mind please post some pictures of the new mast step (and of your repair work). It's gotta have a pin or something to go inside the mast bottom... also it has to let the main halyard run free also out of a hole in the bottom of the mast. also, if you found any other references for the Dagger I'd appreciate that too. another question...the drain hole in the stern, is that only for draining the hollow between inner and outer hull? the only way i can drain the "person" area (don't know what that part of the boat is called...where we sit :-) " is to bail it out. thanks so much for your reply.
mallemang is offline
