SailNet Community - View Single Post - Perkins 4108 engine & parts
post #1 of Old 07-18-2012
VKrouch
Guest
Posts: n/a
PERKINS 4108 ENGINE & PARTS
Perkins 4108 engine in good running condition for sale including mostly
new spare parts for most components of the engine. Selling the engine
and spare parts in bulk as a package for the best offer, as listed
below.
For further information, photos and complete parts list, contact:
VK
Port Charlotte, Florida 33981
Telephone and Fax (941) 698-5000
Email victoriakrouch@gmail.com
Quantity Description
(1) PERKINS 4108 ENGINE
(1) MUFFLER 2" Muffler
(1) PANEL Instrument Panel
Oil Pressure Gauge/Water Temperature Gauge/Volt Meter/Tachometer
(1) Fuel Gauge Dial New
(1) STARTER with Solenoid
(2) Ignition Key Switch (Assembly Blocks)
(1) ALTERNATOR #7127NSE, 12 v.
(2) ALTERNATOR 12 v.
(2) SOLENOID Starter 1 New 1 Used
(1) REGULATOR Alternator American Bosch (RAB23A20) #28725135
(1) Fuel Injection Pump/Lucas CAV type 128/ DPA 3743F #37309
(2) Fuel Injectors #2645559 New
(2) Fuel Injector Nozzles #33435 New
(1) Injector Seating Support New
(1) Fuel Injection Pump Tool & Bolts
Misc. BOLTS Perkins Engine Bolts
(1) Fuel Injection #1 Cylinder Pipe #35355268 New
(1) Fuel Injection #2 Cylinder Pipe #35354255 New
(1) Fuel Injection #3 Cylinder Pipe #35355263 New
(1) Fuel Infection #4 Cylinder Pipe #35354254 New
(1) Lift Pump to Filter Pipe #35844057 New
(1) Gaskets, Engine, Injection Pump, Etc.
(2) WASHERS Injector Seating, 2 Packs est. 12 washers #33811113 New
(1) Fuel Lift Pump #2641314 New
(1) Oil Cooler New
(4) BELTS #2614B129 New
(1) PIPE Cooling System Copper Pipe New
(2) THERMOSTAT #2485688
(2) CAP Header Tank Fill #2487895
(8) STUDS Cylinder Head Studs, Misc. #0826260
(1) Seal Cylinder Head Cover #0730116 New
(1) Gasket Cover to Cylinder Head #0490724
(1) SEAL Cylinder Block to Housing #2415344
MISC. SEALS Water Pump #NR90001
(2) PLUG Oil Drain Plug
(1) Water Pump with New Parts #U5MW0043
(1) Ferrule Pre-Filter #0566003
(10) IMPELLERS Air Conditioning Impellers
(1) Oil Seal #SKF NAPA 9826
(1) Valve Kit #30004-0000
(1) Impeller Kit Jabsco #6303-0003
(2) Ferrule Fuel Oil Pipe
(1) Sea Water Pump
(1) Crank Shaft Pulley #31147637
(2) Engine Lifting Plates
(2) IGNITION plugs
(1) SWITCH Oil Sending Unit #PS4
(100+/-) GASKETS Misc. Gaskets & Seals Approximately 100 New
(1) Parts Catalog for 4107/4108 Engine
(1) Service Manual for Perkins 4107/4108 Engine
(2) Manuals for Perkins 4107/4108 Engine
(1) INVERTER 4000 Watts XANTREX
(1) INVERTER LINK 2000 XANTREX New
Photographs are available upon request and at: PERKINS 4108 ENGINE & PARTS
