SailNet Community - View Single Post - 104th Running of the Chicago / Mac
post #12 of Old 07-19-2012
Sanduskysailor
Re: 104th Running of the Chicago / Mac
So what's the plan? Saturdays forecast show lighter air with more air on the Wisconsin shore. Friday looks like a beat. Hopefully I'll be at the party when you guys are beating up the lake in 15 knots. If the waves are bad, overtim your main a little and a have the jib out a little more than normal for a beat. It will help you drive up in the waves. And by all means keep the boat flat. Get those fannies on the weather rail.
3 tips for a first timer- 1. never go inshore at Sleeping Bear dunes no matter how good it looks. 2. Always check the current at the last can after Grays Reef channel before turning east into the Mac straits. Current with you- down the middle, against you north edge of the straits to the bridge. 3. The odds for inside at the Maintou Islands are 90% . Going outside is 10%. Have a very compelling reason to go outside.
Sanduskysailor is offline
