SailNet Community - View Single Post - Adding woodwork below
post #3 of Old 07-20-2012
overbored
overbored's Avatar
Re: Adding woodwork below
looks a bit like teak in the cabin. the roof or cabin top is most likely cored. this is a layer of fiber on both sides of a core material. by the looks of the electrical wiring clamps being screwed to the under side of the cabin top it is cored. you could add screws to the under side but a more typical way is to glass a stip of wood to the inside of the top and then screw into it. or glass the new bulkhead to the cabin top with a strip of glass about 3" wide on each side of the joint
"GOLD RUSH" PRINDLE 16
overbored is online now
