If they're bolted to a big chunk of wook.. replacing the wood and then sealing it from moisture intrusion is a very good idea. As for removing the core and potting it with thickened epoxy, that's always a good idea on a cored deck or hull.
Having the chainplates bolted to the hull via a turnbuckle is useful, since you can adjust the tension on the chainplate. However, you really need to make sure the hull section you're attaching it to is properly reinforced to take the load of the chain plate, especially, if the chainplate was attached someplace else to begin with.
