SailNet Community - View Single Post - Bow Eye?
Thread: Bow Eye?
post #4 of Old 07-22-2012
Stumble
Re: Bow Eye?
NEVER, EVER, EVER use 5200 on anything on a boat. Unless you have seperated the deck-hull joint, there is no equipment that should be bedded down with 5200. It is a permanent, as in can't ever be removed bedding, that typically involves cutting away at the underlying fiberglass to break something free.
If you need something that permanent use epoxy. For everything else 4200, or 4000uv if it's exposed to the sun.
Greg
Stumble is online now
