SailNet Community - View Single Post - Fishfinder vs depth sensor
post #29 of Old 07-23-2012
miatapaul
Old enough to know better
I use the cheapest Canadian tire fishfinder avaialble( pirahna)
Had an Eagle fishfiner once. The rubber face stuck the buttons too often, so I switched. Get a spare. You can't often get them repaired in the tropics. Tape two 6 volt dry cells together and you can sound an entire area from your dinghy ,or scout out a pass before going thru.
The fuse kept getting disconnected, so I soldered wires onto the ends of a fuse. Contact guaranteed now.
Till the fuse blows and you have to get out the solder gun.
Sent from my ADR6425LVW using Tapatalk 2
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
