SailNet Community - View Single Post - Corsair 24 Mk II as a first boat?
post #12 of Old 07-25-2012
peterchech
Re: Corsair 24 Mk II as a first boat?
Brak are u seriously saying that your corsair tacked between 175 degrees? Seems a tad exaggerated no? I have sailed a corsair 27 and it went upwind just fine.
Monohulls are optimized, typically, for pointing. If you are capped at hull speed, the only way to go fast is to improve pointing. However every racer knows that pinching upwind is slower than bearing off a few degrees and keeping speed up. Same goes for multis. You may lose 5 degrees of pointing, but your higher overall speed means you go faster even upwind than a mono. Polars and all...
peterchech is offline
