SailNet Community - View Single Post - Honda 2hp 4-stroke
post #2 of Old 07-26-2012
dabnis
Re: Honda 2hp 4-stroke
You are lucky it was fresh water. Suggest you remove the plug, drain all the fuel and oil, tip the motor in all positions, blow everywhere you can with compressed air. Squirt a little light oil in the plug hole, ground the plug wire and slowly turn it over a few times. With the oil and spark plugs out invert the motor in all positions again. Re-fuel, new oil, new spark plug,
turn over slowly a few times, making sure there is no hydrolock, then try to start. You can ground the plug and check for spark before hand or just try to start it. At this point you don't have much to lose.
Paul T
dabnis is offline
