SailNet Community - View Single Post - atomic 4 igniition points
post #5 of Old 07-28-2012
kd3pc
kd3pc's Avatar
Re: atomic 4 igniition points
Originally Posted by jp67047 View Post
We tune it each fall, with a complete change of plugs, wires, condenser, cap, and rotor. It runs good until the points burn. We have tried changing the coil also. Could this be some kind of distributor problem?
Thanks
then you are at the distributor/timing/dwell, or else leaving the key on too long...something is causing current to flow for too long...not sure, but you may have a ballast resistor that has failed....but they usually fail opening which would cause the engine to NOT start at all.
kd3pc is offline
