Re: Atomic 4 backfiring thru carb, no power
The only way you can backfire through your carb that I know of is, You are firing with your intake valve still open. So either your timing, Firing order is way off or you have a sticky valve.
"Problems cannot be solved by the same level of thinking that created them."
