SailNet Community - View Single Post - Fishfinder vs depth sensor
post #36 of Old 07-29-2012
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: Fishfinder vs depth sensor
I spent most of the day chasing the transducer wire from the pedestal to near where the old transducer is. While at it, I found a cracked PEX connector for my freshwater system. I no longer wonder why the water pump comes on at night... (now fixed)
Anyway, I tried the Garmin transducer through a bag of water and the hull, and it worked fine. I first tested the unit in my slip, and placed the transducer directly in the water, and it read 7' at low tide. I tested again with the waterbag, and it read 6' 3" (I figure that this spot is about 9" below the water line) I then connected everything up, in preparation to set the transducer in epoxy (I forgot my sandpaper and the attachment for my drill anyway) and lo & behold, the transducer worked without being set in epoxy!
I still plan on setting it in epoxy, but wanted to share for anyone interested that the Garmin echo 200 unit works fine shooting through the hull of my O'day 35.
eherlihy is offline
