SailNet Community - View Single Post - Gulfstar 37's Pro's & Cons
post #9 of Old 08-02-2012
DougSabbag
Captain S/V Triumph
DougSabbag's Avatar
Re: Gulfstar 37's Pro's & Cons
For whatever value, I have found Gulfstars to be a good tough boat for the money.
They have "over built" hulls since they were designed before the advent of CAD which allowed a lot less layup (per the computer) to be done to the hull construction.
But, the deck stanchions allow their decks to rot, because they didn't put epoxy around the stanchion bases; so you could have an extensive project in replacing the wood in the deck, and ideally, adding some epoxy where the stanchions bolt through the deck.
Considering the quality of the interior cabins' is mostly veneer, you could also spend a lot of time / effort / money improving that area. Or not, your choice.
If the chainplates in a 37' GS are inside the interior cabin walls, you might want to change those. (see my earlier thread: Triumph) Well, change them anyway. :-)
But, overall, "for the money", a GulfStar is a tough work horse, and will take quite a beating. It is up to you how much pleasure you get out of her.
DougSabbag is offline
