SailNet Community - View Single Post - Redoing shore power correctly
post #9 of Old 08-03-2012
Maine Sail
Maine Sail's Avatar
Re: Redoing shore power correctly
Originally Posted by hellosailor View Post
If you're using "household" parts for the AC on a boat? Make sure to use the SCREW TERMINALS on the outlets, not the easy push-in slots for the wires. The problem is that the push-in slots just make an edge contact on the wire, and that contact will corrode (even ashore) resulting in a hotter higher-resistance contact. Using the screw contacts gives you a better connection.
Better yet use captive spade or ring terminals and not braided wire direct to the outlet.
______
-Maine Sail / CS-36T
Maine Sail is offline
