Re: Bedding Deck Hardware With Butyl Tape
Originally Posted by meljabro3
We just bought 2 rolls! thanks for inspiring my wife to get started in the re-fit of our boat!
What would you suggest when re-bedding lexan windows?
If not through bolted butyl used as a shim the Dow 795 or Sika 295UV (with special primer) used as the "bond". I run butyl around the inside edge and the sealant the outer edge. The butyl makes a perfect shim for the sealant and also acts as a back up seal..
______
-Maine Sail / CS-36T
