SailNet Community - View Single Post - Bedding Deck Hardware With Butyl Tape
post #208 of Old 08-08-2012
meljabro3
Re: Bedding Deck Hardware With Butyl Tape
If not through bolted butyl used as a shim the Dow 795 or Sika 295UV (with special primer) used as the "bond". I run butyl around the inside edge and the sealant the outer edge. The butyl makes a perfect shim for the sealant and also acts as a back up seal..
Actually I'm thinking that they're called deadlights? I'm not sure though.
My windows are lexan plastic bolted over cutouts. There aren't any frames or anything, just the lexan
meljabro3 is offline
