Old 11-15-2006
sailingdog sailingdog is offline
There is usually a gasket under the collar that tightens up when you snug up the collar against the threaded ring on the boat socket. Shouldn't be a problem if the gap is where you've indicated. The upper flange just above where you're pointing to is not designed to seal the fitting, but to prevent the black screw down collar from dropping off the end of the cord.
