SailNet Community - View Single Post - Tohatsu 4hp 4 Stroke won't run on integal tank
post #3 of Old 08-13-2012 Thread Starter
Ward H
Re: Tohatsu 4hp 4 Stroke won't run on integal tank
Yep, running from the bay thru the channel and to the slip, it ran great on the external tank, even though it was dripping gas at the fuel line connection.
That's why I tried the internal tank again and when I still had problems, I re-connected the external tank it ran fine so I could get it back into the slip.
I agree it is a partly clogged fuel line or maybe a bad selector valve? Doesn't let it switch fully to internal and does not fully shut off internal so now it has gas in it it leaks back around the fuel line connection? Never leaked there before because it never had gas in the internal tank before?
Ward H is offline
