SailNet Community - View Single Post - Power tool for sanding toe rail
post #19 of Old 08-17-2012
baboon
Re: Power tool for sanding toe rail
I took my teak toe rails down to bare wood 2 yrs ago. After trying a few options I had the best luck using a cheap heat gun (under $20 at big box store) and very good quality scrapers. The scrapers are available at better marine stores and woodworking shops, these are not the paint scapers you get at the hardware store. They will leave a very smoth surface that can be hand sanded to finish the job quickly. Carfull use of a small finish sander with fine grit paper worked too, the Black and Decker mouse worked very well. I found any power sander took too long on the old varnish, but also tended to take off too much material it got close to bare wood.
baboon is offline
