SailNet Community - View Single Post - Catalina Mainsail Traveler
post #6 of Old 08-21-2012 Thread Starter
Re: Catalina Mainsail Traveler
I found the information that I needed. It is a Garhauer Traveler which is no longer made.
The way the traveler sheets are held into the traveler car is a poor design. A steel sleeve was crimped over the ends of the line, slipped into a whole and held in place with a set screw. The traveler car is made of aluminum. Over time the steel sleeve fuses to aluminum car and can not be removed. I need to replace the sheets, which I am sure date back to 1995. I called Garhauer and was told the only fix, until I can afford another traveler, is to tie the new sheets to the U bolt, (where the main sheet snaps on to the traveler), and make it work that way. Not the prettiest rig in the world, but it does work.
Kinne is offline
