SailNet Community - View Single Post - In-mast furling
Thread: In-mast furling
post #15 of Old 08-23-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: In-mast furling
Add on to my previous post, comments relating to other folk's comments.
Sail Area .... yes furling main is smaller than non furling but I'm not sure I agree with "far less sail area". I'd like to compare.
Lack of Battens is for me a negative, yes.
Friction, no matter how you look at it is a problem and yes you do need to winch in. I also find that keeping the outhaul under control as you furl is a problem. Good furling requires some tension on the outhaul so I find myself having to let out some outhaul then wind, repeat sequence. I do wish there was some way to keep tension on outhaul without the need for a second pair of hands. (If any of you are sitting there thinking I'm not doing it correctly please let me know.)
We've not had problem with wrinkles or jamming nor do I have a problem flattening the main but I am loath to ease halyard tension in light airs which I'd readily do with a non furling main. This may be prejudice on my part. I have noticed that when furling it seems to load up towards then of each rotation. This may be need for maintenance of the furler itself and I'll be addressing that when we pull her out of the water next month.
Previously I would have thought in mast furler would be a deal killer but by the time we bought the new girl I'd largely overcome that concern. Now I'm quite happy with it though I couldn't say with 100% certainty that I'd go in mast if I was building a new boat or re masting an old one.
Andrew B
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
