SailNet Community - View Single Post - Vented Loop Design?
post #1 of Old 08-26-2012 Thread Starter
eherlihy
Learning the HARD way...
eherlihy's Avatar
Vented Loop Design?
While trying to route my new transducer cable, I encountered the vented loop from the heat exchanger before it enters the waterlift muffler. I had a choice, undo the two 3/4" hoses, or undo the one " hose.
I decided that rather than messing with two hose clamps, one would be easier - that was a mistake. After I removed the clamp, I could not get the hose to let go of the barb. A little more pressure, and snap, off came the hose with the barb still inside.
So off to WM to get a new one. No joy at the closest WM, so 55 min drive in the other direction where they had 5 in stock. The new vented loop is one with the duckbill valve, and the old one had a barb with a hose.
The original looked more, or less, like this (except it was old - 1987 black plastic);
Here is a pic of the new one;
Because the loop is mounted HORIZONTALLY (not vertically) under the cockpit floor, I was unsure if this new fangled style would work. Fortunately, I found a brass barb fitting that fit, so I bought that too.
I put a little pipe dope on the threads, installed the brass barb, and installed the new vented loop in the old location - after correctly routing the transducer cable.
So, the question for the collective; would the new-fangled style have worked?
eherlihy is offline
