SailNet Community - View Single Post - tinkering with cabinetry and tabbing
post #2 of Old 08-27-2012
CarbonSink62
Load Bearing Member
CarbonSink62's Avatar
Dock
Re: tinkering with cabinetry and tabbing
I would trust the builder; if it is only tabbed on one side, that's likely enough. Is that tabbing starting to fail?
That other bulkhead is probably not tabbed because it is not structural; you might tab it into place this year and find you need to remove it next year (the Klammer/Franchen guide block adjustment fitting might be behind there). I'd leave it alone.
The red strands are probably the same as tracers in a halyard or sheet but in the FG mat material. Red probably means xx thickness, blue might mean yy thickness. That's just a guess.
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
