SailNet Community - View Single Post - Went to the boat for a sail..and its Flooded!!!
post #28 of Old 08-27-2012
SchockT
SchockT's Avatar
Re: Went to the boat for a sail..and its Flooded!!!
Originally Posted by NewportNewbie View Post
Yes. It goes from the engine compartment directly into the bilge. Mine was designed that way. When I bought it the whole was plugged by a previous owner and it was dammed up so it was accumulating in front of the large pump under the stairs and never getting to the bilge. The boat yard removed that when I had it pulled and made sure I had 2 working bilge pumps. I would check and see if your was not plugged previously. Sounds like you have something similar to what I had.
No, the sump under my engine definitely did not have limber holes from the factory. It is smooth clean gelcoat. I haven't decided if I want to drill some, but my experience with the oil leak has me thimking maybe not!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
