SailNet Community - View Single Post - IB30 cutlass bearing removal
post #2 of Old 08-27-2012
CalebD
Tartan 27' owner
CalebD's Avatar
Re: IB30 cutlass bearing removal
ISLANDER BAHAMA 30 sailboat specifications and details on sailboatdata.com
Most cutless bearings are sleeved, especially in a strut.
DIY?
- remove shaft
- if press out method using threaded rod, washers, small section of pipe matching ID of bearing does not work (and it usually doesn't), then
- hack saw blade to score the sleeve of the bearing. Once a clean cut is made you peel it in on itself.
Here is a very good step by step guide: Replacing A Cutlass Bearing Photo Gallery by Compass Marine at pbase.com
Everybody has one:
CalebD is offline
