Old 08-28-2012
Capt. Gary Randall's Avatar
Capt. Gary Randall Capt. Gary Randall is offline
Capt. Gary Randall is on a distinguished road
Re: Boy killed by lightning in our anchorage, what would you do?
If you are walking along a beach in the water you'd become a conductor to ground. This is not acceptable. Most sailboats have a ground plate is attached to the mast and bonded through out all the hull fittings including the shaft, if it is a inboard. You are much safer aboard the vessel as the mast becomes the conductor and discharges the lightning through the ground plate. captg
[SIGPIC] The only difference between an ordeal and a adventure is your attitude!
