SailNet Community - View Single Post - IB30 cutlass bearing removal
post #3 of Old 08-28-2012
kentg
Re: IB30 cutlass bearing removal
I replaced mine last year on a 1981 B30, it is sleeved, cut it in two or three spots and it should come out real easy. Be careful the sleeve is very thin after you get through the rubber bearing. I used a threaded rod about 1/2 inch and washers to press the new bearing in. Good luck!
kentg is offline
