SailNet Community - View Single Post - Rule Mate 2000 Bilge Pump sticking on?
post #19 of Old 08-28-2012
Pecornelius
Re: Rule Mate 2000 Bilge Pump sticking on?
YES, I have the exact same problem. The Rule Mate 2000 bilge pump is sticking on. I must lift it up and out and hold it 90 deg to normal to make it stop. The instructions say no one way check valve. ...but I tried a small rubber flapper type check valve very near the pump to see if trapped water in the 1 1/8 inch line was causing this. Negative results. It still sticks on. The manufacture should be alerted to this bad design and recall them. Seems no body cares. I will try to contact Rule...somebody has to stop this.
Pecornelius is offline
