SailNet Community - View Single Post - Sailboat without a mast
post #4 of Old 08-28-2012
rgscpat
Water Lover
Location: New Mexico, USA (Heron, Elephant Butte lakes); Arizona (Lake Pleasant)
Re: Sailboat without a mast
Of course, a sailboat is very unlikely to have as much internal volume and room for stores as a power boat of the same length, and sawing off the mast will deprive the boat of the ability to steady its motion via the sails or to save money by sailing.
-- And, cruising sailboats of that size usually have much more of a displacement hull design than powerboats and don't have room to install a much bigger engine, so a mast-less traditional sailboat would become a slow powerboat without the option of having a big engine to get out of trouble.
-- Also, you'd probably be paying to motor around with a big heavy lead or iron keel that isn't doing much to earn its deep, and which would restrict you from entering shallow water. (You could maybe saw off and sell a lead keel for good money, but then your boat would be even less stable.)
-- And powerboaters and sailors would probably both be suspicious of a boat that doesn't know which side it's on.
But, as "they" say, your sea miles may vary.
PS: Better than sawing off the mast would be saving it on land somewhere safe, so as to preserve a sailing option as well as the boat's resale value, or perhaps selling it -- the mast is worth a lot more as a mast than as some sort of hokey antenna support or whatever.
rgscpat is offline
