SailNet Community - View Single Post - Sailboat without a mast
post #8 of Old 08-28-2012
knothead
Re: Sailboat without a mast
Originally Posted by pedalsteel View Post
I'm new to this forum. Am planning to purchase a used 30' sailboat but I'm not interested in sailing. I would like to remove the mast except for about 8 feet for antenna mounting. Would like to do the great loop and not have to worry about a mast, also very economical cruising. Would removing the mast as described have any ill effects on the vessel?? Thanks Al.
If you're serious, and I have my doubts. I would recommend that even though you don't want to sail, you should leave the mast on the boat. If you are planning on passing under bridges that don't open, it would be possible and certainly more sensible to set up the mast to lower when you need to.
You don't have to sail it, but leave the mast on the boat. It will roll your guts out if you remove the spar.
knothead is offline
