SailNet Community - View Single Post - Sailboat without a mast
post #14 of Old 08-29-2012
AncientTech
Senior Moment Member
AncientTech's Avatar
Re: Sailboat without a mast
Originally Posted by Minnewaska View Post
All good points above that I won't repeat. I will add that the mast is a pricey item and destroying it will seriously devalue the boat. Do you plan to flush that money down the drain? You will not be able to sell a sailboat without a mast, as you are the one and only I've ever heard of being interested in one. Replacing it could be a seriously higher percentage of the boat's value than you might think.
Excellent point, as an example say you have a 25/26ft boat either a Columbia or a Pearson. If you are lucky you will be able to find a replacement mast for $3000. In some cases that will be what you spent on the boat in the first place. Get a bigger boat and the price goes up drastically.
"I am of the mind that anything with a proper sail attached to it has the potential to profoundly alter ones concept of the world."
Morgan 22
Naples, FL
AncientTech is offline
